Need Crankshaft Nose Dimension
I was wondering if someone here can provide spcifications for the nose of the 428 crankshaft. I have spent quite a lot of time researching with no success. Specifically, I need the diameter of the nose where the harmonic balancer fits. I discovered today that my harmonic balancer can be easily pulled off by hand and I'm pretty sure that's not right. I believe it should be a light interferance fit. If I knew the spec for the crankshaft I could verify which part is defective, eg; damper or crank.
Appreciate any help.
Ted
