Looks like you have what you need. Rotate the alternator up 180* on the large mounting bolt, then remove your current bottom rod and attach it to the top bolt on the triangular mount into the water pump. Make sure your bolt is long enough. Re attach adjusting rod to alternator. I use a 7440xl belt. Best picture I have right now.
fiaroadster
