Old 07-07-2013, 05:14 PM
blykins blykins is offline
Default B2 Motorsports - Cliff Rosson All-Aluminum 331 SBF Build
Going to start throwing some pictures up here pretty soon of Cliff's build. It's based on an aluminum Dart block, 4.030 x 3.250, using a Callies Dragonslayer crank, Oliver rods, and a set of Mahle pistons/rings.
Heads are a set of Trick Flow Twisted Wedge Track Heat 185cc heads, loaded with Ferrea valves and PAC springs/retainers. Cliff chose a set of Webers for the top end, so the cam (custom Comp Cams hydraulic roller) will reflect that.
More to come...
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
