I will take a look at that Larry. I am redoing those side panels for a better fit and putting on vinyl that matches the dash and seats. I also have hinge covers. I will also be notching the side panels for the cowl supports like you did. That was a good one. It makes the panels fit a lot better. We will call that the Larry side panel mod.
Thanks.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
