We had a very similar issue.
As strange as it sounds the solution was simple - a smaller not bigger master cylinder bore size but dont guess.
Measuring the pedal ratio is the key then call a brake and clutch person who knows what they are talking about and they will tell you what bore size you need.
Our clutch went from literally a rock to a pleasure.
Good luck
