Originally Posted by bktlist
yes its a 9"
if you have a warrantee with the rear by all means call who you bought it from. if not, it is very easy to nic a seal when sliding an axle into the housing.
the seal is cheap to buy, but will require you to pull the axle to replace it.
it isn't rocket science ...if you don't want to tackle it yourself any competent garage has the know-how to do it.....maybe even while you wait...
call where you get your daily driver worked on.....
