07-17-2013, 08:06 PM
TX
Doug, Joe will fix you up. If he needs a hint, show him this:
" Mechanical speedometer pick-up
All TKO’s have the same Ford style speedometer pick-up bore located on the driver-side rear extension. You must use a Ford T-5 speedometer cable end. (Note: If you are using the electronic pick-up, you must plug the hole for the mechanical speedometer with a metal plug, part # 30-360-1X available from authorized TREMEC
distributors to prevent oil leaks. Do not use the black rubber shipping plug."
Source:
http://www.tremec.com/anexos/TKO_Ins...ps_117_117.pdf
Sam
