Old 03-19-2002, 12:26 PM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Brandon, The trans mount I use is a Napa # 602-1334. If the angle seems too high you can lower the trans crossmember by using spacers between the frame and crossmember. This is the way they lower the trans tailshaft on the big block cars since the engine sits lower. I don't normally use any spacers and the alignment is ok. Using the Napa mount you may have to file a small amount from the trans where the mount bolts on. Once you try and install the mount you will see what I mean. It's usually less than a 1/32 of an inch. This is on the Tremec 3550 trans.
Don
