Originally Posted by mickmate
Manual Rack Rebuild
Fred has a good point, it's mainly the sleeve bearings on the end. Secure it and give them a wriggle to see if they're loose. It can be a pain to replace them. The small pinion bearing wasn't the right size from the Jag dealer and I sourced those elsewhere.
Mickmate do you make a full length tie rod. The cut ,sleeve and weld thing always gave me the willy's?
