Brandon,
By all means you are not being a pain in the arse!
To drop the transmission mount lower, if need be, we simply cut four pieces of 5/8's or 1/2" pipe to the desired lenght. (Never did like to see a stack of washers)
Then you can place the mount at your choosen angle. The stock angle you end up with should be well within spec's!
Keep the questions coming. Somebody here will surely have the answer.
DV
