Old 07-21-2013, 08:01 AM
bill37341 bill37341 is offline
Cobra Make, Engine: Scratch-built 427 MR
I had a problem of blistering paint on a Cobra about 25 years ago, in the same area. I had used a lacquer based filler instead of bondo and the lacquer obviously hadn't cured. Heat from the exhaust caused the filler to blister. Ground the area back to the fiberglass, filled with bondo, problem solved. Fortunately, the paint wasn't metallic.
