X2 on what Jim said .
Do NOT use them as support when you`re under the car.
I have used them ( both ) to pull mine up on a rollback when they couldn`t get under the car . The difference is the bolts are in tension and you`re only fighting rolling resistance up a ramp vs a shear load . Four bolts in shear with about 2000 lbs on them ???? No way .
