Old 07-24-2013, 05:49 PM
poboy427 poboy427 is offline
Cobra Make, Engine: SPF #373,Shelby FE Alum Block #077, 488 stroker, Tunnel Port, Dual-TMP DP Holleys
Default composite or polymer gear for FE?
I'm running a Comp cams solid roller. I was looking into buying a composite dizzy gear. They seem to be unavailable in .500 for aftermarket dizzy and also unavailable in .467 for FE though they are available for SBF in .467. I guess the difference, even though they share the same shaft diameter, is either the pin location or gear pitch??
Anyone know of a vendor that sells composite gear for FE? I mean, the composite or polymer gears as they are sometimes called, have been around for a few years now. You would think that these gears would now be available for FE.
Ray
