Just installed a cockpit cooling system using off the shelf parts. Preformed inlet duct, High temp 3" dia. ( race ) ducting, Marine bilge fans in the front wheel wells, hose clamps and some 3" connector/unions.............On the last 500 mile run through the center of Ca we had air movement. High ambient at slow speed is just air movement. At speed it works. I did not install a shot off valve. Not normally a SoCal requirement. Winter runs to Willow Springs Raceway will be the test...........
