Originally Posted by tkb289
I did not know there was room under the hood, especially with a big block motor. Any photos of where it mounts? Will you be using any special heat shielding?
It mounts on a pedestal directly behind the passenger side wheel. You remove the panel behind the wheel for access. I have the optional heat vent and heat shields, and I am going to add either heat shlelding on the bottom of the pedestal, an insulated battery cover
Thermo-Tec : Battery Wrap Acid Absorbing Heat Barrier, or both.
