Bump Steer CR round tube chassis
Hi All
after covering my first 2000k's I now need to sort this sucker out and bump steer seems to be my biggest issue in the way of a relaxed drive. I am finding when driven hard through corners their is no obvious bump steer but try and point the car straight on any lumpy bumpy road and hold on tight and a busy time on the wheel is needed and full conerntration. The front end is the guilty one from what i can tell , but I would guess this would normally be where you would start. I have found some threads on the forum refering to the square chassis CR but my search did not find anything on the round one so i hope someone out there has already dealt with this and might know the best way to go about fixing this sucker.I understand the priciples of what BS is so its more about solution.
Any direction is welcomed
Scoob
