Pressures sound high, in my clubbies I run 24 (albeit a couple hundred kg lighter still).
For my clubbies I like 5 deg castor, less and it becomes twitchy around the straight-ahead. I experienced the same when I used to drive an 81 Range Rover with 2" lift - even with a solid front axle. Some castor shim plates soon fixed it.
Treeve
