Old 08-01-2013, 10:01 AM
RedSnake351's Avatar
RedSnake351 RedSnake351 is offline
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Originally Posted by Danr55 View Post
I bad a solar pro lem when I switched to.a.different salt. The alignment was off about 1/4 inch. Any load caused a god awful squeal. Check the alignment and .make sure it's tight.
Dan, isn't it a ***** when you wake up with a bad hangover and try to write a sensible sentence? I know, I also have that problem.
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
Last edited by RedSnake351; 08-01-2013 at 10:02 AM.. Reason: Trying to write a sensible sentence.
