Old 08-01-2013, 03:07 PM
TEAM THREE WHEE TEAM THREE WHEE is offline
If you have not repaired the wheel, we can straiten the bends out. We have a wheel straiting machine that will press it back to where it needs to be, we can do bolt on and knock-off wheels. Some wheel repair companies beat the wheel close and then machine the bead seat round again. This will cause the bead seats to be under size, since the diameter is just .3mm, and then the wheel will have vibration issues since the tire will nolonger fit correctly. Since we manufacture wheel we have the correct bead seat gages to check this. Wheel repair companies do repair, but are not manufacturers so do not know the details of wheel manufacturing. We know the wheel you have since we make the wheels for Trigo. the cost to repair is 95.00 plus ups
