[quote=sambo;1255560]I've ordered poly bushes to replace the solid upper/lower bearings on my QA1 shocks. Got sick of all the crashing and bashing.[\QUOTE]
Sambo, from our experience you just need to poly bush just one end of each shock to give you the compliance you are looking for. Just make sure your shock mounting alignment is true or you will chop out bushes, this is also the other reason we only poly bush one end, usually there is always one end with misalignment requiring a bearing.
