Old 08-02-2013, 06:27 AM
Legless's Avatar
Legless Legless is offline
Cobra Make, Engine: DRB 302 Ford HO Block
Hi Marc,
If your coil is mounted on the engine or close to a heat source I would suspect the coil has been damaged by heat. I doubt it would be an intermitant earth as this probably wouldn't improve with cooling of the components.
Good luck, finding the problem but I strongly suggest changing the coil.
cheers
Legless
Legless
If its not blown it sucks!
