Old 08-03-2013, 12:11 PM
Roberts1996 Roberts1996 is offline
Cobra Make, Engine: Everett Morrison Cobra, running a Ford 351 Cleveland and a AOD transmission.
Default Nervous Steering.
I would like information pertaining to alignment on my EM Cobra. I started my Cobra in '96 and completed in '05. I have 15K miles on the clock and my BFG's 245/60/15's are wearing great. My alignment spec's are Camber is set at 0. Caster is set at 3 degrees and Toe-in is at 1/8". These were the spec's I got from EM when they were in Tampa. The steering is "nervous", kinda darty and would like some advice on how to possibly correct this nervousness. I am running with Tubular A-arms, Aldan Coil-overs and a manual Mustang II rack. I replaced both the front and rear rubber bushings with Poly, and adjusted the wheel bearings. My power plant is a 351 Cleveland and total weight is 2780. Any advice to correct the nervous steering? Thanx, Robert.
