  #56 (permalink)
Old 08-06-2013, 03:33 PM
strictlypersonl strictlypersonl is offline
Originally Posted by prp289 View Post
Will the 15" 5 pin FIA-Style wheel fit on front Wilwood brake
Yes, if the rim profile is the same as a 6-pin wheel, which I believe it is.
and will it fit the ERA Rear end?
On the bolt-on outboard-brakes, we mount the rotor hat between the wheel and the hub face. That moves the wheel about 0.20" out. That will probably fit without further backside machining. What we'll have to check is whether there is enough thread left over on the stock studs to use the special lug nuts.
