After many years of having my wife pump the pedal i found a new method. I get a long piece of clear plastic tubing sized to keep a tight fit over the bleeder outlet on the disc. I then crack the bleeder valve just so there is a slight amount of pedal pressure. I run the tubing from the bleeder valve out over the top of the fender back to the resevior. That way I can watch the fluid and the amount of bubbles that is comming up the tube. When I get to the point of not seeing bubbles I tighten the valve so I get good pressure in the pedal. Has worked very well for me.
