Originally Posted by strictlypersonl
It looks like the rear studs will have to be replaced in order to leave enough threads for the adapter nuts. That's a little more complicated than it sounds: they are threaded in and then staked on the backside. Replacing them will require some machining.
That sounds like a PITA. You know, like
"Step Three - Pull Engine, Trans. and Rear."
