Old 08-12-2013, 05:59 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
If you can get to the cables from the battery and starter replace them all with the biggest and best quality cable you can find. Check with your local battery stores. Many of them will make up a set of cables with the appropriate terminals and lengths you'll need. Take the old ones in with you so they can make up the correct length.
Two of our club members have had the same problem and the re-manufactured cables have cured both.
X2 the clean terminals and connecting points.
DonC
