renman, I've used about 50 of the Griffin radiators over the years and they work real well. I've had some on the road for 8 years with no problems. I normally buy off the shelf for what I need from Summit or Jegs. The 1" row radiator runs about $170, the 1.25 runs a little more. If you need to have one custom made it will run you into the $400 range. One of the main problems I have found in cooling these cars is the electric fan. I had several checked from Scott's, Permacool, and several others to measure the actual flow. Almost all were about 1/2 of what they stated for CFM. I now use the Spal fans exclusively, they put out about 90% of the stated cfm. I have yet to build a car with the Griffin and Spal that runs hot. The Spal fans draw a lot of power so I wire in a 30 amp relay for the circuit. Hope the info helps.
Don
