The PO knows what the cylinders of that car look like from a Snap On bore scope.
I watched as a expert FE engine builder inserted that camera into each cylinder and rotated that motor full stroke for each one. A gasket set is NOT fixing the problem.
That inspection was done AFTER the boys at ERA attempted their "fix."
The issue was obvious....The motor needs to be re-built as stated in the ad.
