Old 08-17-2013, 08:00 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Default Free!! Well almost,,,
I set of REAR chrome Pro-Shocks for a CR Cobra or MX. (Still in "dirty" box). Never used. PART # PRO # 9901 GONE
CR's "stock" pedal box.
Aluminum special spacer studs for rear shocks. New but aged... GONE
Shipping $25.00
CR's rear coil MOUNTS-Will separate for $15.00 shipping.
Don't forget I have a brand new hub assembly for 11" up grade front brakes!
SPINDLES
BEARINGS
MASTER CYLINDER (napa reconditioned-new)
7" Corvette BOOSTER (NEW) (This is a huge up-grade to the M-II Booster)
SPINDLES
NEW:
BEARINGS
CALIBERS WITH BRAKE PADS!!
BRACKETS FOR THE ABOVE
11" ROTORS! NEVER USED
Everything here is a direct bolt in on an M-II brake system.
You DO need to get a small proportioning valve and GET RID OF THE M-II VALVE!
My thought is this IS the single biggest upgrade to the Cobra other than a side-pipe modification!
$500.00 and I will take care of the shipping cost.
DV 231-869-4608
