Originally Posted by bobcowan
Your compression isn't that high, even at sea level. If you're having problems with slow cranking, it's probably not the starter, it's somewhere else.
Consider buying an off the shelf starter from Autozone. Pick one from a 5.0 Mustang with a manual transmission. You are getting a high torque starter, in a small package. The advantage to that is that if it dies, you take it back for a new one.
That's what I'm using, and it works just fine. It didn't cost $200 either.
Like this one:
BesTest 03-0508X - Starter | O'Reilly Auto Parts
it has been spinning the 13.5 to 1 compression 331 stroker in my race car since 2004!!!!!!!!!!!!!!
be sure to ask for one for a standard transmission, there is a difference in the one for an automatic and a standard, it's the nose length......
David
