Old 08-18-2013, 11:33 AM
ERA 778's Avatar
ERA 778 ERA 778 is offline
Cobra Make, Engine: ERA #778 427SC Keith Craft FE 428 stroker
What transmission, bellhousing, clutch, etc. are you using? I used a Quicktime bellhousing and McLeod clutch and diaphragm style pressure plate hooked up to a Richmond Gear five speed. I had to go with the aluminum spacer on the slave and a 1" master cylinder to get adequate travel. Even now I sometimes think about going up in master cylinder size again since the move into reverse is still marginal. At first I was concerned about pedal effort, but that has really not been an issue.
