Old 08-18-2013, 02:31 PM
DAVID GAGNARD's Avatar
Originally Posted by SF_SN888KE View Post
I'll call Powermaster on Monday, but the shaft turns BOTH directions. I think the bendix(?) is busted.
My Powermaster does not have the NOSE cover on the front of the starter. Looks like the stock Mustang (others including Ford Racing) have the NOSE cover. Will that make a difference? It seems to be a protection function.
I like the idea of having a separate starter solenoid and connections on the back, and stock parts.
The Powermaster 3803 has a 3/4" offset
Only concern is the clocking position. The stock starters have a fixed position and I hope it clears the 4" rails and the 8 qt Avid oil pan.
the O'Reilly's 95' Mustang SVO starter was $95 (plus $25 core - and I don't have a core) and a Ford Racing starter was $295!
You can most likely pick up a junk starter at a junkyard for 5 bucks and use it for a core.....
BTW: The one I got from O'Rielly's is for an early 90's Ford T-bird with a 302 and a standard transmission.......it is the same starter some sell as a Ford Racing starter for 295.00!!!!!!
David
DAVID GAGNARD
