Evan,
I can answer that. If the frame has no body, then sure. If the frame already has the glass shell attached, then no.
The glass shell would be virtually impossible to remove from the frame, I've tried it. Not only is it riveted it is also glued with the strongest compound I've ever seen. This is especially true with the later HST and SA cars. Tom (Toms Motorsports has also tried without good results)
Best, Bret.
B. Ewing
