Ok I have progressed a little. Trying to do things one at a time to not get too lost in the task. It sounds simple, just chuck an engine and box in it maaaattee!
This is the complete fuel system minus the wiring. Those puch fit fittings are a real pain to put on... until i found out you need lube...
Drivers side engine mount, probably a little stronger than needed... but I didn't want it to 'fall' out.
Passengers side engine mount.
Sorry the photos are a bit boring at the moment, I hope to have some dry sump plumbing photos etc up as soon as I can get the parts...
Next job is to get the tailshaft sorted, also the shifter needs to be modified so I can reach it. The seat sits a fair way back and I just cant reach it even though it is 100mm further back from the factory position...
