  #138 (permalink)
Old 08-31-2013, 09:13 PM
cscobra cscobra is offline
Cobra Make, Engine: ERA #766, FE V8, Toploader
Dan, I just noticed the part of your message about the engine tilter--I did not use one. My engine came with a lifting plate bolted to the intake manifold. It had three large holes in the vertical lifting portion. We started off using the forward hole thinking that a lot of tilt would be necessary, but it was too much! We ultimately used the center hole instead with no problems and with good results.
