Thread: Clutch problem
Old 09-03-2013, 01:15 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Danr55 View Post
I would look first at the clutch cylinder. Sounds like it has worn a soft spot in the middle and needs to be replaced. THat would be doubly true if it happens when you sit for a minute holding the clutch down. The fluid leaks around the piston.
Master cylinder?
Originally Posted by Bob Broberg SPF667 460BB View Post
DrDuc, do you have a slave cylinder? Sounds like when mine died from seal leak. Just like what Dan said. Cheap replacement.
AZ Bob
Of course he has a slave cylinder. He could also have a hydraulic throwout bearing which is not cheap, gearbox out job.
Originally Posted by James Stern View Post
Check the cable.
What cable?, It's hydraulic.
Gary
