If all you have are the two small fans in front of the radiator, that might be your problem. Those things don't do much good since there is very little shrouding to direct the flow. A rear mounted puller will move a lot more air through the engine compartment. Summit Racing and Jegs are good places to look for one. Get the largest one you can mount on the radiator.
