BJ, what you fail to understand is that it's a ridiculous disease. I wish I could just cut a piece of steel in the vice, drill a few holes and bolt things up using whatever nuts and bolts I had handy. But no. First I would draw something up, then get it laser cut, then bend as required, then if it was right and didn't need to be made again, polish/paint or anodize the item. Then the bolts I use would have to be not only stainless with nyloc nuts, but to add to the nightmare they must be the same thread, the same length and the same manufacturer. It's taking every bit of self control not to replace the only blue fitting left on the car knowing what's involved to complete the task. I actually find myself daydreaming about it. Now that's crazy!
Regards.
Mando
