Old 09-12-2013, 06:37 AM
BBQCYCLEWERKES BBQCYCLEWERKES is offline
Cobra Make, Engine: 2007 BDR FR Boss 302
I switched out an automatic to a tko 600 in capteddies cobra. bought most of the parts from vendor Mike Forte. I spent approx $4500 in parts alone if I remember correctly. transmission, flywheel, ram clutch system, driveshaft, new wilwood pedals, hyd clutch with new master cylenders, 3 billet reservoirs, shifter, etc. if you want a std trans, buy a cobra with one in it. much cheaper in the long run. swap takes alot of time also. pull interior, remove and mount new pedal assy, swap trans and poss make/buy new crossmember, patch hole in tunnel for auto shifter and cut new std shift hole, fab and mount all hyd clutch lines and reservoirs, etc. just my 2 cents worth of experience. good luck with your purchase and enjoy.
