Old 03-22-2002, 10:55 AM
Larry Hills Larry Hills is offline
Some columns have replacable bushings at each end. Start by determing what car the column came out of. Then check a repair manual. If you can't determine what make of car it came out of look for a company that sell bearings & bushings. Take the column with you. Also, measure the dia. of the steering shaft before you go.
Hope this helps..
Larry K Hills
