Old 09-15-2013, 05:54 PM
FWB's Avatar
FWB FWB is offline
Originally Posted by bliss View Post
I have a 428 FE engine in my car from back in the day (60's).
I was informed when I purchased it that it was a police interceptor but a mechanic recently stated that it was a cobra jet 428.
I'm not a mechanic - is there a way to confirm what 428 it is for sure?
Thanks.
the block casting numbers will be the same as a 390, so use a pencil in a spark plug hole to measure the stroke, 390=3.78, 428=3.98
if it still has the iron heads on it the casting number for CJ heads is C80E-N
it will be between the center spark plugs
the PI motor will have other numbers, you could try to see the cast date on the block, its above the oil filter adapter. anything before like 67'ish will be a reg 428...
post some pictures
Fred B
