The stock wiring should have a wire for a cigarette lighter (white wire from fuse #2) that is not used. Also, if there is no heater, there should be a wire for the heater blower (light green wire - fuse #3). I put a double outlet (from JC Whiney, I think) and a single one in mine. The double is off the light green line, so hot when the ignition is on; the other is hot all the time.
