Old 09-17-2013, 10:26 AM
Rick Parker's Avatar
If MSD or Ford Duraspark distributor, first check the ignition module for correct ohm rating. Look on MSD's website. Heat will generally manifest an ignition problem. This is happening to the Primary side of your ignition, hence the tach grounding.
Rick
