Old 09-20-2013, 10:49 AM
Bob S. Bob S. is offline
The reason the radiator was angled back is because of interference with the sway bar and steering rack . If you change the sway bar you could straighten the radiator by moving it forward but it would also need to be moved down to clear the inside of the body . This might cause ground clearance problems .
If you do this it will clean up the inside of the engine compartment and look much better but you won't notice any increase in cooling .
