Old 09-21-2013, 08:16 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Bill:
I always give it about 30 minutes after a run before I check the oil level to give everything a chance to drain back down. Checks sooner than that will give you an indication of gross oil loss but 1/4 of a quart down can easily be attributed to oil still in the system. 1/4 qt. is 8 oz. or 1 cup of oil. Not a whole heck of a lot when you consider a 7 or 8 qt. total system
DonC
