  #270 (permalink)
Old 09-21-2013, 07:33 PM
Barry_R Barry_R is offline
Very good to hear that its running well - finally!
Had not heard from you for a while...and kept intending to follow up on progress.
Took a little arm-twisting to get us credit for the "used" EZ-EFI as a trade up for the xFI package. We really tried to tune this thing on the chassis dyno and the EZ-EFI simply would not let us grab the tune-up it needed at that RPM level. It needs to dwell at a given RPM and load for the self learning function and for some reason it never would stabilize enough to get the job done.
I was pretty confident that the xFI system would work just fine since it lets you manually manipulate all the variables without the system needing to "learn". If you see a dead lean area that's causing crazy manners you just go in there and throw fuel at it until it stabilizes & tune from there.
Great job!
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
