It depends on the power you need, type of pump, etc. -8 AN is good for >700 HP. I used Aeroquip PTFE braided line, which should stand up well to ethanol. I also used Aeromotive in-line filters - 100 micron at the tank, and 40 micron at the carb before the regulator. Can you can provide more detail on your setup?
