Yay! Road tested and this $20 piece works very well indeed. You just unscrew it until you have a bog on heavy acceleration, then turn the screw back in until the bog goes away. The zip tie test shows the secondaries are now opening nicely. What a pleasant surprise from a relatively inexpensive little item (it was only three dollars more than the Holley spring kit itself).
