09-25-2013, 12:30 PM
KY
Can't do that when going from a hydraulic to a solid. Too many differences between the two.
Even when you think about actual duration......a hydraulic lifter is always in contact with everything. A lifter on a solid cam has to move a distance before the rocker arm makes contact with the valve stem.
Lobe shapes are completely different...solid roller lobes are more aggressive and the lift will be greater.
