Originally Posted by ERA Chas
Only at idle-at any throttle above that it's fully depressed.
Uhhh, surely you realize that Holley specifies adjusting the accelerator pump at WOT. Like this:
First you will need to check the adjustment on the pump. To do this you will open the throttle all the way (WOT). Push the pump arm lever down and then adjust the pump override spring to obtain .015" clearance between the pump arm and lever.
Source:
Holley Performance Products Frequently Asked Questions
